configure flowmon collector
configure flowmon collector collector_name
Description
Configures a created collector where Flow Monitor sends information.
Syntax Description
collector Specifies to send flow information to a collector.
collector_name Specifies the name of the created collector. Range is 32 characters.
Default
N/A.
Usage Guidelines
You must configuresrc-ipv4-address, which is a dotted decimal representation of the local address. If not configured, the collector cannot be activated.
You must configure dst-ipv4-address, which is a dotted decimal representation of the IPv4 address of a collector. If not configured, the collector cannot be activated.
Optional configuration parameters include the following:
The following command configures a created collector with no additional parameters:
# configure flowmon collector ctest dst-ipv4-address 21.1.1.100  src-ipv4-address 21.1.1.1
This command was first available in ExtremeXOS 32.2.
Platform Availability
This command is available on ExtremeSwitching 5420, 5520, and 5720 series switches.
